2020-04-17 12:41 AM
Hello everyone
How can I download earlier versions of STemWin library from ST website?
Best regards
2020-04-17 12:59 AM
Update: Inside cubeIDE i´m still able to get them via "Help -> Embedded Software Packages Manager" :) If you don´t use cubeIDE, just install it, download the package, you need, find it on your hdd afterwards and make a copy :)
2020-04-17 12:55 AM
Normally they are contained inside the firmware packages for your mcu ... For F7 it´s:
Scroll down and click on "select version".... As i just have seen, ST removed the older versions of these packages :( So maybe you find someone here, who still has an old one and can send it to you. Which one is needed ?
2020-04-17 12:59 AM
2020-04-17 1:06 AM
God bless you man ☺�? :tulip:
