STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
cubemx fmc setup for stemwin and STM32F767ZI
​I'm trying to use cubemx to setup a project to use STEMWIN on my nucleo 144 board; however, I'm having a problem with FMC setup, specifically, I get a yellow triangle on SDRAM1 and SDRAM2.  I'm not exactly sure how to configure these for use with th...
JBlac by Associate III
  • 1458 Views
run simulator too slow!
I am using touchgfx 4.10.0 on WIN7 pro 64bits,the cpu is I7-4800MQ,memory is 8G ddr3,ssd 256GB.I creat a simple project base on stm32F746G Discovery Kit with two buttons,when I click "run simulator",it takes 11 minutes to popup the simulator window! ...
xxian.12 by Associate
  • 1991 Views
STM32F767 Jpeg configuration
Hi everyone,For some time now I am trying to run the hardware Jpeg codec so far with no results. The whole configures Hal libraries without using it. My assumptions at the beginning are to encode one block of 8x8 MCU in the gray scale. The problem th...
kulfi27 by Associate II
  • 752 Views
STM32L476G-EVAL TFT LCD white Screening Problem
Hi I am using STM32L476G-EVAL board. L476G Demonstration Program operation was good at purchasing time. and I burned other program hex using ST-Link. (ex GPIO, CAN example)Some days was later. EVAL board TFT LCD Screen was All White. and it seems to ...
jkoo by Associate
  • 1795 Views
