STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Run TouchGFX Simulator on CUBEIDE.
Hi everyone,I'm trying to compile the touchGFX project (Simulator only) using the GCC Cross toolchain from the CUBEIDE but after importing the project to my workspace the build button is not enable.I wonder if an additional configuration or compiling...
FDigi by Associate III
  • 1523 Views
TouchGFX 4.14 bug while compilling
I just install TouchGFX 4.14 version and find I can not pass compile process in KEIL enviroment. the reason is file name in TouchGFX_proj\746_customercontrol\TouchGFX\generated\images folder is different with KEIL project. So I have to change the fil...
THao.1 by Associate
  • 1206 Views
TouchGFX template problem
In version 1.15 of the TouchGFX online user guide, a template for the STM32G071 + X-Nucleo-GFX01M1 development board is referenced (in the section: Development / Scenarios / TouchGFX on low Cost Hardware) but in the software TouchGFX Designer this te...
AGall.2 by Associate
  • 1082 Views
TouchGFX and video play
Dear all,I'm developing an application with a STM32750N8 and I'm using TouchGFX for the GUI. I am using a 4.3 "RGB (parallel) display with 480x272 resolution but I will also need to use a 7" 1280x720 (parallel RGB) display.Since I have to play videos...
Luca G. by Associate III
  • 788 Views
Global Color Palette / Themes
I would like to use a central color palette for my application. But I haven't found a good example of how to implement that. There doesn't seem to be anything in touchGFX designer to implement this.My first attempt was to place some colortype varia...
Dfarr.1 by Senior
  • 1438 Views
