STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
About JPEG Codec decoding time length
Decoded VGA size JPEG images on STM32H750B-DK.As a result of measuring the decoding processing time, it takes three times as long as the processing time of Application note.I would like to know the reason why the processing time is so long.Applicatio...
NYana.1 by Associate
  • 1378 Views
Resolved! About LCD drive voltage
Is it possible to set the LCD drive voltage to 4.5VDC in STM32L073?When using a VA liquid crystal panel an LCD, it is said that it cannot be driven by 3.6VDC.
HMura.6 by Associate II
  • 2530 Views
How to detect Release of item of scrolllist ?
I want work with scrolllist this way: touching and dragging -> scrolling the list of files, pressing (without drag) and releasing -> go to directory after releasing.Question: how can i get Release event? Scrollist has onle 2 events - setItemSelectedC...
EEuge by Senior
  • 3066 Views
Resolved! Problem with custom external loader
Hello i created a custom external loader following this guide. My check code in the main (see the video) works. I can read in memory mapped mode, i can write and i can erase sectors and full chip.I can write to it simple bin files using stM32 Program...
AMerc.4 by Senior
  • 4728 Views
  • 13 replies
Show CURSOR
Hello dear friends,Is there any option or method to show and hide the CURSOR position?The rival product (which I don't like that really much) EMWIN has such an option.
How to read value of textArea?
Hello!I have Scrollist with customcontainer, which contains textArea1 widgetI set text while working Unicode::UnicodeChar buffer[20]; Unicode::strncpy(buffer, FileList[data], 20); Unicode::snprintf(textArea1Buffer, 20, "%s", buffer); textArea1.se...
EEuge by Senior
  • 2503 Views
DSI video mode , howto sync properly?
I place init call for send config to display in generated MX_DSIHOST_DSI_Initto end user codeVidCfg.LPVerticalBackPorchEnable = DSI_LP_VBP_ENABLE; VidCfg.LPVerticalSyncActiveEnable = DSI_LP_VSYNC_ENABLE; VidCfg.FrameBTAAcknowledgeEnable = DSI_FBT...
MM..1 by Chief III
  • 2248 Views
