STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
ScrollWheel Skipping Second Element
I have a weird issue with ScrollWheel. All the elements are displayed properly. However, it seems to be taking no action when scrolling to the last element, and on debugging, I find that the returned index is skipping the second element (0,2,3,4,5)Sc...
BKazi.1 by Associate II
  • 860 Views
Redraw custom widget if its updated
Hello,I create custom widget base on this tutorial https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/custom-widgets.But it is updated on screen only once at the beginning. How to implement auto redraw when internal...
MMa.4 by Associate
  • 1160 Views
Hello, Recently, a former colleague of ours raised a ticket tegarding a LTDC buffer underrun issue that we encountered on an STM32F750. I understand the ticket was closed, but, we don't have access to the resolution.
The ticket in question is: https://community.st.com/s/case/5003W00000BksAFQAZ/ltdc-fifo-underrunPlease share with me the resolution of that ticket.Thank you.
AMunt.1 by Associate
  • 1266 Views
Touch Screen and Camera Connection and Software
1- Does DSI screens work immediately with STM32Fx that support DSI or is driver / complicated programming is required?2- F4 and newer boards support DCMI, what type of cameras would work with this? Is it limited to a set number of cameras? And does i...
Aafg.1 by Associate
  • 1545 Views
Resolved! Assigning external data structure variables in TouchGFX
Hello communityI face the following problemI have a global data structure which contains several member variables, I use this data structure to handle all my global variables needs across my project.Such datatype is delcared in "globals.h", and a var...
Mric.1 by Associate II
  • 3381 Views
