2020-02-17 11:59 PM
Need to protect data access through j-tag, but need to program flash through inbuilt boot loader
2020-02-18 1:20 AM
it is mostly for temporary . after reset it will automatically enable
2020-02-18 2:15 AM
Hi. If you want permanently disable j-tag, you must develop your own bootloader and set RDP level 2. In-build bootloader is not 100% safety. It is already hacked.
2020-02-18 3:59 AM
Is there any other option other than RDP level changing to disable j-tag in stm32?
2020-02-18 4:44 AM
Only RDP level 2 can disable debug access to uC permanently. Other types is easy to hack. Here some info.
What device do you use?
2020-02-18 11:39 PM
STM32H743ZI
2020-02-19 12:28 AM
You've decided not to RDP level 2.
You next most secure option is to RDP level 1 AND configure your JTAG/SWD pins as GPIO inputs at run-time.
2020-02-19 3:00 AM
How to find out swd pins in STM32CubeMX?
2020-02-24 1:03 AM
How to set SWD pins as GPIO pins in STM32H743ZI ?
2020-02-24 2:40 AM
Have a look in the Reference Manual for your stm32. I know it is a big and daunting document, but this is where the answers to most questions are most completely given.
In there is a chapter on GPIO. In there you will discover how to set the MODE to be either digital input, digital output, alternate-function or analog input. SWD is one of the alternate-function options.
Hope this helps (I know you'd solve _this_ question more quickly if I just answered _this_ question. But once you know your way around the Reference Manual you won't need to ask us nearly as many questions),
Danish
