2020-04-08 1:52 AM
The SMPS output voltage can reach 1.8V . That is upper than 1.7V requested.
2020-04-29 10:54 PM
I know that.
Because the volatage for the core actual needed is 1.38V. The internal SMPS output voltage is too big.
It will make IC more heater.
As to,why internal LDO can run at 480Mhz, in my opinion, it is that the LDO area of the chip can bear higher temperature.
