Why am I getting SSL errors/disconnects on a fresh out-of-the-box IOT EVAL KIT?
Mark Symmes
Associate
Posted on July 16, 2018 at 20:07
I have just powered up the STM IOT DISCOVERY NODE board B-L475E-IOTA2.
It connects to my AWS IOT endpoint and then gets disconnected immediately and the USB Virtual Serial Console show many, many errors.
1. Attached is a log of the entire sequence from the console.
2. Here is my event log as created by a custom lambda function that I use in the AWS IOT ACT sections
Event 1:
'principalIdentifier': 'b30893ac3d6ca2a9abaceaae005f9c55293343fde8b5e633eee342621fd045f2',
'timestamp': 1531764176425,
'sessionIdentifier': '7e5f7933-1106-4f18-a599-8aa1653fa897',
'clientId': 'STM32',
'eventType': 'connected'
Event 2:
'timestamp': 1531764176995,
'eventType': 'disconnected',
'clientInitiatedDisconnect': false
3. Here is the output of an openssl test run on a linux box:
♯ openssl s_client -connect ag5td4i5bbh9e.iot.us-east-1.amazonaws.com:8883 \
            -tls1_2 -CAfile aws_root_ca.pem -cert b30893ac3d-certificate.pem.crt -key b30893ac3d-private.pem.key
CONNECTED(00000003)
depth=2 C = US, O = 'VeriSign, Inc.', OU = VeriSign Trust Network, OU = '(c) 2006 VeriSign, Inc. - For authorized use only', CN = VeriSign Class 3 Public Primary Certification Authority - G5
verify return:1
depth=1 C = US, O = Symantec Corporation, OU = Symantec Trust Network, CN = Symantec Class 3 Secure Server CA - G4
verify return:1
depth=0 C = US, ST = Washington, L = Seattle, O = 'Amazon.com, Inc.', CN = *.iot.us-east-1.amazonaws.com
verify return:1
Certificate chain
0 s:/C=US/ST=Washington/L=Seattle/O=Amazon.com, Inc./CN=*.iot.us-east-1.amazonaws.com
i:/C=US/O=Symantec Corporation/OU=Symantec Trust Network/CN=Symantec Class 3 Secure Server CA - G4
1 s:/C=US/O=Symantec Corporation/OU=Symantec Trust Network/CN=Symantec Class 3 Secure Server CA - G4
i:/C=US/O=VeriSign, Inc./OU=VeriSign Trust Network/OU=(c) 2006 VeriSign, Inc. - For authorized use only/CN=VeriSign Class 3 Public Primary Certification Authority - G5
Server certificate
-----BEGIN CERTIFICATE-----
MIIGGjCCBQKgAwIBAgIQLnQIWjfERfw1k/3WWKINNTANBgkqhkiG9w0BAQsFADB+
MQswCQYDVQQGEwJVUzEdMBsGA1UEChMUU3ltYW50ZWMgQ29ycG9yYXRpb24xHzAd
...redacted...
EudlMhIxRFh9vGtdeEtiGyWiysk+El47beznoRT9fmJUHoxgKgsznbc2K0STY5hK
05vnq6DeWRLXoQYZoJm9ysbfVsRx9QB3YRy0C79Cie5bvmO7ib2sQ0OdfB42eg+v
I9KM/MH7QgMiCeHVBnoxdysrLBF9cyGt3MJHwzVi
-----END CERTIFICATE-----
subject=/C=US/ST=Washington/L=Seattle/O=Amazon.com, Inc./CN=*.iot.us-east-1.amazonaws.com
issuer=/C=US/O=Symantec Corporation/OU=Symantec Trust Network/CN=Symantec Class 3 Secure Server CA - G4
No client certificate CA names sent
Client Certificate Types: RSA sign, DSA sign, ECDSA sign
Requested Signature Algorithms: ECDSA+SHA512:RSA+SHA512:ECDSA+SHA384:RSA+SHA384:ECDSA+SHA256:RSA+SHA256:DSA+SHA256:ECDSA+SHA224:RSA+SHA224:DSA+SHA224:ECDSA+SHA1:RSA+SHA1:DSA+SHA1
Shared Requested Signature Algorithms: ECDSA+SHA512:RSA+SHA512:ECDSA+SHA384:RSA+SHA384:ECDSA+SHA256:RSA+SHA256:DSA+SHA256:ECDSA+SHA224:RSA+SHA224:DSA+SHA224:ECDSA+SHA1:RSA+SHA1:DSA+SHA1
Peer signing digest: SHA512
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 3431 bytes and written 1576 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-GCM-SHA384
Session-ID: 5B4CDA304BA0D786F1BC36C9C5E1EDE0F7BC5503CAAAF0E31217B38C3F685E1B
Session-ID-ctx:
Master-Key: 4B14DA7D355E76C88BF0D0B83AD4656F376DA631103F3E5F0EC9178766A4E47754AC6614B6075824511AEE7B4E83CE85
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1531763248
Timeout : 7200 (sec)
Verify return code: 0 (ok)
#iot-node #b-l475e-iot01
0 REPLIES 0
