2024-06-05 7:59 AM - edited 2024-06-05 8:09 AM
Dear sir/madam,
I want to implement a USB audio DAC . And I have already followed the USB library for configuration of related files. When I am connecting the stm32f401VC discovery board USB connector to the host pc its displaying in the notification area. But its not producing good audio quality. So kindly check the related files . I am attaching all files of the project.
Software Development Environment : KEIL MDK ARM
Software Development kit : STM32F401VC Discovery Kit
Programming Language : Embedded C
Thanks & Regards
Satyabrata Senapati(Firmware Engineer)
2024-06-07 9:16 AM
Hi @ssena.1514
Have you tried this example on cube firmware STM32Cube\Repository\STM32Cube_FW_F4_V1.28.0\Projects\STM32F401-Discovery\Applications\Audio\Audio_playback_and_record
2024-06-07 10:41 AM
Yes this application I have already ported to stm32f401vc microcontroller & its working perfectly.
But what I am asking is ,it's a different application which is not present.
And I have followed some other controller
Usb audio dac application to port in to stm32f401vc controller.
So my question is why its producing hiss noise at audio output.
The possible mistake could be
1.wrong configuration of usb library
2.or it could be in audio buffer management.
So kindly see the attachment files and reply where I have done the actual mistake.
Thanks & Regards
Satyabrata Senapati
2024-06-11 8:07 AM
Hi @ssena.1514
I'm not sure buffer audio management would impact the noise. However, you may try to increase sampling rate of audio file. In fact, sampling rate and bit depth should match between the source audio and the DAC configuration.
2024-06-11 9:24 PM
Thanks for your response. Let me check.
