2010-05-20 10:05 PM
TIM repetition counter
2011-05-17 4:51 AM
Hi benison,
For example in upcounting mode: if the repetition counter is equal to 0, the update event is generated at each overflow. if repetition counter is equal to 1, the update event is generated at each 2 consecutive overflows. . . . if repetition counter is equal to 255, the update event is generated at each 256 consecutive overflows. That's what I have understood when I have used this feature. Thanks to correct me if you find something else. You can find in the reference manual a figure that explains this. Refer to ''Update rate examples depending on mode and TIMx_RCR register settings'' (or something like this). MCU Lüfter, be low powerWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
