2023-09-28 8:12 AM
I'm trying to migrate my Azure IoT application from a BG96 to a BG95-M3, both from Quectel. I have solved some problem due to the difference in use of the uart3 pins of the BG96 and BG95. Should I make more modifications to the software? Is there a document that covers migration at the software level?
Thanks
2023-11-09 9:46 AM
Hello Roger,
After modifying these files: at_custom_modem_specific.c, at_custom_modem_signalling.c, at_util.c, cellular_service_cmd.c, at_util.h and at_custom_modem_specific.h. I already send data to Azure.
Greetings
2023-10-03 4:39 PM
Hello @JVica.1 ,
There has been a case created to resolve this question and we will be reaching out to you directly.
Regards,
Roger
2023-10-11 7:12 AM
Hello Roger,
The frequency bands are different for the BG96 and the BG95 and also the values to select the bands with the command AT+QCFG= "band" so the file at_custom_modem_specific.h must be adapted. Is there a version adapted for the BG95 of this file available?
Greetings
2023-11-09 9:46 AM
Hello Roger,
Greetings
