stm32L051 Comparator input impedance
mailbox
Associate II
Posted on March 23, 2016 at 15:11
I'd like to monitor battery voltage (V~8volts) using comparator and voltage devider with two resistors (1-10M). Coud you please specify analog comparator input impedance, so i can select appropriate resistor value. I'd like to minimize ground current throught divider.
Thanks!
#stm32l1 #comparator
2 REPLIES 2
Radosław
Senior III
Posted on March 23, 2016 at 16:30
Whit succes i use 5M impadance devider for comparator. Check in datasheet input leakage current.
mailbox
Associate II
Posted on March 24, 2016 at 10:13
Thank you for reply, 5M is ok
