2021-02-28 9:27 PM
2021-03-01 12:35 AM
It is used internally by the ADC during conversion, i.e. you don't use it to modify the conversion result.
2021-03-01 11:42 AM
It is used internally during a conversion and is some sort of multiplication factor. What I am after is how to translate the CALFACT number into the actual amount results are multiplied by.
2021-03-01 12:09 PM
That's not documented.
You may be mistaken in considering it to be a multiplier.
Why can't you use the ADC as intended and as described?
