2018-03-14 12:25 AM
Hello friends.
I need read 4 channel from ADC (PA0, PA1, PA2, PA3).
I read reference manual:
But i don't know, how to switch and measure next channel. Now, I'm reading only PA0.
My init function:
void ADC_init()
/* Peripheral clock enable */
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_ADC1);
LL_ADC_SetCommonClock(__LL_ADC_COMMON_INSTANCE(ADC1), LL_ADC_CLOCK_SYNC_PCLK_DIV4);
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC1), LL_ADC_PATH_INTERNAL_NONE);
LL_ADC_SetResolution(ADC1, LL_ADC_RESOLUTION_12B);
LL_ADC_SetDataAlignment(ADC1, LL_ADC_DATA_ALIGN_RIGHT);
LL_ADC_SetSequencersScanMode(ADC1, LL_ADC_REG_SEQ_SCAN_DISABLE);
LL_ADC_REG_SetSequencerLength(ADC1, LL_ADC_REG_SEQ_SCAN_ENABLE_4RANKS);
LL_ADC_REG_SetTriggerSource(ADC1, LL_ADC_REG_TRIG_SOFTWARE);
LL_ADC_REG_SetSequencerDiscont(ADC1, LL_ADC_REG_SEQ_DISCONT_DISABLE);
LL_ADC_REG_SetContinuousMode(ADC1, LL_ADC_REG_CONV_SINGLE);
LL_ADC_REG_SetDMATransfer(ADC1, LL_ADC_REG_DMA_TRANSFER_NONE);
LL_ADC_REG_SetFlagEndOfConversion(ADC1, LL_ADC_REG_FLAG_EOC_UNITARY_CONV);
/**Configure Regular Channel */
LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_0);
LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_0, LL_ADC_SAMPLINGTIME_480CYCLES);
LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_2, LL_ADC_CHANNEL_1);
LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_1, LL_ADC_SAMPLINGTIME_480CYCLES);
LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_3, LL_ADC_CHANNEL_2);
LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_2, LL_ADC_SAMPLINGTIME_480CYCLES);
LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_4, LL_ADC_CHANNEL_3);
LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_3, LL_ADC_SAMPLINGTIME_480CYCLES);
LL_ADC_Enable(ADC1);
And my reading:
void readADC(uint32_t *value1)
LL_ADC_REG_StartConversionSWStart(ADC1);
while (!LL_ADC_IsActiveFlag_EOCS(ADC1)){}
LL_ADC_ClearFlag_EOCS(ADC1);
value1[0] = LL_ADC_REG_ReadConversionData12(ADC1);
Any idea how to get to the next channel? Or how to scan 4 channels and return the value of all 4 ADC channels?
#adc-reads #nucleo-f767zi2018-03-14 1:49 AM
Here is my function modofication:
void ADC1_init()
LL_ADC_REG_SetSequencerLength(ADC1, LL_ADC_REG_SEQ_SCAN_DISABLE);
And read from ADCx and channels 0-7 with easy peasy filter.
uint16_t adc_read(ADC_TypeDef *ADCx, uint8_t channel)
uint32_t ADC_value = 0;
uint32_t voltage = 0;
for (int i = 0; i < 16; i++)
/* Select analog input */
ADCx->SQR3 = channel;
/* Clear status register */
LL_ADC_ClearFlag_AWD1(ADCx);
LL_ADC_ClearFlag_EOCS(ADCx);
LL_ADC_ClearFlag_JEOS(ADCx);
LL_ADC_ClearFlag_OVR(ADCx);
/* Start Conversion */
LL_ADC_REG_StartConversionSWStart(ADCx);
/* Wait for conversion to complete */
while (!LL_ADC_IsActiveFlag_EOCS(ADCx)){}
ADC_value += LL_ADC_REG_ReadConversionData12(ADCx);
voltage = ((ADC_value >> 4)*3300)/4096; /* calculate voltage */
/* Retrieve result */
return (uint16_t)voltage;
