2018-05-23 4:36 AM
I am trying to create microsecond level delays for an interrupt to be generated. The problem I am facing is that when I go below 60microsecond it starts having a +1.5us offset for prescalar of 215 and the signal edge starts slight fluctuations. That offset goes down to 0.6us if I use a pre-scalar of 107. Also, I am not able to get any delay below 3us. While I expect using the 216Mhz clock I should be able to get minimum 4.629 ns . Can Anybody give some example code or share their experience about the minimum achieveable precise delay in STM32F MCUs. I have attached an excel file of my observations.
I have the following settings:
2018-05-23 5:00 AM
Dear
ktcengineer
,please share with us your code implementation how you measure the timings. Do you use oscilloscope?
Best regards,
Tilen
2018-05-23 8:25 AM
I am using Oscilloscope.
2018-05-23 8:26 AM
It may also be useful to mention that I have used one of the example code which gave me precisely timing delay of upto 10us with no offset.
