2016-05-25 5:56 AM
Hello, I am trying to developed an application with STM32F7. I managed to integrate the GUI with stemwin (appears on the screen, it's ok) but the Touch screen does not work so I could not use the buttons of the interface. I need some help.
2016-05-25 6:32 AM
I recommend you that you run and get inspired from “STemWin_SampleDemo� example code in
at this path STM32Cube_FW_F7_V1.4.0\Projects\STM32756G_EVAL\Applications\STemWin\STemWin_SampleDemoYou can get further information from emwin user guide of SEGGER
https://www.segger.com/downloads/emwin/UM03001_emWin5.pdf
.-Hannibal-
2016-05-25 1:16 PM
I tested the example “STemWin_SampleDemo� but not working (white screen)
2016-05-25 1:38 PM
Ok, but what board, specifically, are you using?
The EVAL demo probably isn't going to run on the DISCO.Did the screen run with a demo app when you got it? Does reflashing it get you back to a working demo?2016-05-25 2:31 PM
thank you -Hannibal- I solved the problem
2016-05-25 2:33 PM
Solution: STM32Cube_FW_L4_V1.4.0\Projects\STM32L476G-Discovery\Demonstrations
