2016-02-25 2:23 AM
2016-02-26 3:40 AM
Hi
Does anyone have any idea?2016-02-26 7:43 AM
Hi Mucit23,
1- If you add a breakpoint in the DMA2D_IRQHandler, is it executed only one time?2- Did you tested the example STM32Cube_FW_F7_V1.3.0\Projects\STM32746G-Discovery\Examples\DMA2D\DMA2D_MemToMemWithPFC?Are you facing any issue running this example?If there is no issue faced with this example, you can compare it with your own project to identify what is going wrong.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
