2012-03-22 9:13 AM
First of all i know that FSMC in STM32F2xx does not support SDRAM devices. But i think that with little effort it should somehow work reasonably.A good example of how the others try to this is athttp://www.myplace.nu/avr/dram/index.htm
.A nice explanations can be found athttp://www.eecs.umich.edu/eecs/courses/eecs373/Lectures/stever_old_lectures/lec9.pdf
Is there somebody who tried to do something anything with an interface to SDRAM on STM32?The main reason why i am over the fact of thinking is that SDRAM is several times cheaper than SRAM. So maybe there already exist some DRAM with interface wich looks like SRAM.So any ideas?Regards,T.Kamenicky #stm32-sdram-fsmc-dram-interface2012-03-22 10:06 AM
SDRAM != 1980's DRAM
If you need the cost/performance/size that SDRAM/DDR/DDR2 offers, you need a micro that supports it out of the box. Like the Atmel AT91SAM9xxx or Freescale Kinetis K60 ST's solution is PSRAM, what kind of memory size/cost are you looking for?2012-03-22 10:46 AM
The PSRAM is quite problem, for example on farnell.com store there is none available :\
Cost should be max 8,-euro and size from 16MbitsAccess time max 1us for 16bits parallel access.2012-03-23 6:33 AM
what's the problem?
Mouser has 16MB SRAM @ US$82012-03-23 7:46 PM
''Mouser has 16MB SRAM @ US$8''
Is it MBit or Byte...? We recently used Cellular RAM..works on FSMC on Bank0 (RAM). Still testing it, however no complaints so far. Except the package is BGAWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
