2024-07-25 6:47 PM
After normal power-on, the MCU does not run, but as long as something is used to shield it, it will return to normal. Help to see what is the reaso
2024-07-26 3:50 PM
Hi @leo12345678 ,
Try to remove R13, pull-up resistor on reset pin, it is not required. we have one internally.
Hope it helps.
STOne-32.
2024-07-29 12:24 AM
We remove the R13 and it still didn't work, but we blew it with a fan for a while and it came back to normal, so what's going on here? Thank you very much!
2024-07-29 2:30 AM - edited 2024-07-29 2:31 AM
crystal oscillator not starting?
is this board your own design, or purchased from some supplier?
if the latter, is it your own firmware? Do you have any known-good reference firmware?
