2018-06-13 1:42 AM
STM32CubeMx 4.26.0 RTC Reset always during INIT
The generated Code
void
MX_RTC_Init
void
RTC_TimeTypeDef
sTime
RTC_DateTypeDef
sDate
/**Initialize RTC Only
hrtc.
Instance
RTC;
hrtc.
Init
HourFormat
RTC_HOURFORMAT_24;
hrtc.
Init
AsynchPrediv
127
hrtc.
Init
SynchPrediv
255
hrtc.
Init
OutPut
RTC_OUTPUT_DISABLE;
hrtc.
Init
OutPutPolarity
RTC_OUTPUT_POLARITY_HIGH;
hrtc.
Init
OutPutType
RTC_OUTPUT_TYPE_OPENDRAIN;
if
HAL_RTC_Init
hrtc)
HAL_OK)
_Error_Handler
(__FILE__, __LINE__);
/* USER CODE BEGIN RTC_Init 2 */
/* USER CODE END RTC_Init 2 */
/**Initialize RTC and set the Time and Date
sTime
Hours
0
sTime
Minutes
0
sTime
Seconds
0
sTime
DayLightSaving
RTC_DAYLIGHTSAVING_NONE;
sTime
StoreOperation
RTC_STOREOPERATION_RESET;
if
HAL_RTC_SetTime
hrtc,
sTime
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
/* USER CODE BEGIN RTC_Init 3 */
/* USER CODE END RTC_Init 3 */
sDate
WeekDay
RTC_WEEKDAY_MONDAY;
sDate
Month
RTC_MONTH_JANUARY;
sDate
Date
1
sDate
Year
0
if
HAL_RTC_SetDate
hrtc,
sDate
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
/* USER CODE BEGIN RTC_Init 4 */
/* USER CODE END RTC_Init 4 */
But Older versions generated code (which was correct)
void
MX_RTC_Init
void
RTC_TimeTypeDef
sTime
RTC_DateTypeDef
sDate
hrtc.
Instance
RTC;
if
HAL_RTCEx_BKUPRead
hrtc, RTC_BKP_DR0)
0x32F2
hrtc.
Init
HourFormat
RTC_HOURFORMAT_24;
hrtc.
Init
AsynchPrediv
127
hrtc.
Init
SynchPrediv
255
hrtc.
Init
OutPut
RTC_OUTPUT_DISABLE;
hrtc.
Init
OutPutPolarity
hrtc.
Init
OutPutType
if
HAL_RTC_Init
hrtc)
HAL_OK)
_Error_Handler
sTime
Hours
0
sTime
Minutes
0
sTime
Seconds
0
sTime
DayLightSaving
sTime
StoreOperation
if
HAL_RTC_SetTime
hrtc,
sTime
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
sDate
WeekDay
RTC_WEEKDAY_MONDAY;
sDate
Month
RTC_MONTH_JANUARY;
sDate
Date
1
sDate
Year
0
if
HAL_RTC_SetDate
hrtc,
sDate
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
HAL_RTCEx_BKUPWrite
hrtc,RTC_BKP_DR0,
0x32F2
these two lines are missed which always makes the RTC reset
if
HAL_RTCEx_BKUPRead
hrtc, RTC_BKP_DR0)
0x32F2
HAL_RTCEx_BKUPWrite
hrtc,RTC_BKP_DR0,
0x32F2
2018-06-19 9:05 AM
Hi
V.Varadharajan
,Thanks for your feedback,
In fact, the idea is to let the user insert his own code using habitual USER TAGs when he doesn't want to re-initialize RTC peripheral.
As you can see, in CubeMX 4.26 version, we have added USER TAGs in the MX_RTC_Init(void) where user can add his own code.
static void MX_RTC_Init(void)
/* USER CODE BEGIN RTC_Init 0 */
/* USER CODE END RTC_Init 0 */
RTC_TimeTypeDef sTime;
RTC_DateTypeDef sDate;
/* USER CODE BEGIN RTC_Init 1 */
/* USER CODE END RTC_Init 1 */
hrtc.Instance = RTC;
hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
hrtc.Init.AsynchPrediv = 127;
hrtc.Init.SynchPrediv = 255;
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&hrtc) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
sTime.Hours = 0x0;
sTime.Minutes = 0x0;
sTime.Seconds = 0x0;
sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
sTime.StoreOperation = RTC_STOREOPERATION_RESET;
if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
sDate.WeekDay = RTC_WEEKDAY_MONDAY;
sDate.Month = RTC_MONTH_JANUARY;
sDate.Date = 0x1;
sDate.Year = 0x0;
if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
Also, in addition to the backup register, there are others solutions to remain the RTC initialization. It depends on user application. For example, you may also use RTC & PWR flags to determine whether RTC is already initialized or a HW/SW reset has been occurred. So, we can not force user to use backup register solution to remain
RTC initialization.
Hoping it helps you, please do not hesitate to contact me for further details.
Best Regards,
Mohamed.
2018-06-13 2:01 AM
Hi
V.Varadharajan
,Thanks for your feedback. This is now reported internally for further check.
Could you please precise which STM32 MCU and which Cube firmware you're using.
We will update you ASAP.
Khouloud.
2018-06-13 4:49 AM
Dear Sir
I'm using NUCLEO-446ZE Board
2018-06-13 4:50 AM
The Cube Firmware version STM32Cube_FW_F4_V1.21.0
2018-06-13 5:14 AM
Thanks for the details. This will help us when reviewing the reported point.
Khouloud.
2018-06-19 9:05 AM
Hi
V.Varadharajan
sTime.Hours = 0x0;
sDate.Date = 0x1;
sDate.Year = 0x0;
RTC initialization.
Best Regards,
Mohamed.
2018-09-20 9:43 AM
But in CubeMX 4.27.0 version void MX_RTC_Init(void) does not contain USER TAGs.
2018-09-20 9:57 AM
MX_RTC_Init(void) does contain USER tag with version 4.27.0.
2018-09-22 4:49 AM
STM32CubeMX 4.27.0, STM32F205RETx, STM32F2 MCU Package v. 1.7.0
File Src\rtc.c Lines 49-91
/* RTC init function */
sTime.Hours = 0;
sTime.Minutes = 0;
sTime.Seconds = 0;
if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN) != HAL_OK)
sDate.Date = 1;
sDate.Year = 0;
if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN) != HAL_OK)
2018-10-15 6:41 AM
Same problem here for STM32F107. ST please add USER tags in the next release !
