2016-06-09 1:34 AM
Hello, selecting nucleoF746 in cubemx (in the nucleo 144 line), i can see somme errors :
1/ the HSE frequency is 8mhz and not 16Mhz, and the clock in not corre ct (RCC not enabled, prescaler not set) 2/ pin PB00 LD1_Green is missing A fixed .iocis attached to this post. #nucleo-f746g-stm32cubemx2016-06-09 2:23 AM
Hi bustico.alexandre,
Thanks for the feedback. I report this internally to our CubeMx team. (just for the RCC, the HSE will be selected in the clock tree when it is enabled by user in the RCC peripheral) -Hannibal-2016-11-08 1:57 AM
Hello bustico.alexandre,
Thank you for reporting the bug you saw.We modified some iocs to solve the issue you highlighted.The modifications are added in CubeMX4.18.BREric DampierreWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
