2025-07-18 5:18 AM - last edited on 2025-07-18 5:45 AM by mƎALLEm
I am looking at a project where I would typically use an SBC, but wondering if ST has enough usb host support to accomplish this with existing usb stack software. If so what would be recommended models?
Thanks for the insights!
2025-08-05 7:20 AM
Hi @scottc19
You can use STM32MCU Finder, to filter out your needs. Also, in AN4879, Table 6. USB implementation on STM32 should help you as well.
About USB HS vs FS would make a significant difference, HS provides much higher bandwidth, reducing latency and improving device responsiveness but might requires external PHY.
For example, STM32H7S3/S7 and STM32F72x/3x embeds HS phy internally.
2025-08-05 8:30 AM
@scottc19 wrote:I am looking at a project where I would typically use an SBC
So maybe look at STM32 MPUs?
https://www.st.com/en/microcontrollers-microprocessors/stm32-arm-cortex-mpus.html
