2023-06-09 1:25 PM
Some of the parameters which can return negative values (not all the time, sometimes positive) are: Power Factor, ReactivePowerReceived, ApparentPowerDelivered, and whatever these parameters are:
Vmom = -162 AEload = -0.174030 Imom = -43 PF = -0.008001 REload = -0.22418
2023-06-09 2:38 PM
For those not familiar with the part or software you're using, is it this?
https://www.st.com/en/embedded-software/stsw-stpm002.html
2023-06-12 3:17 AM
Yes that is what we are using. Are you familiar with this package and why it may send negative values for the above readings?
