2017-11-08 3:33 AM
Generated a project for STM32F746 (Firmware Package for Family STM32F7 v1.8.0) that uses ADC1 + DMA + TIM6 (TRGO) for Keil MDA-ARM 5. Tried to run it - no trigger is received by ADC, so no convertion data is transferred over DMA.
The bug is documented in 'STM32F74xxx STM32F75xxx Errata sheet', page 7 (2.2.1). Workaround is to turn on CLOCK for DAC.
Please fix the bug in code generating .
2017-11-08 6:51 AM
I raised this issue internally to the CubeMx team for further check and investigation.
Best Regards
Imen
2018-02-13 5:22 AM
Hi
Kozyrev.Alexey
It should be available in the next CubeMX release.
I will keep you informed.
BR. Jeanne
