2015-07-24 6:04 AM
Hello Everyone,
I am using new board from STM32 and I added simple page from GUIBuilder from software included to library. When I run my code I click for example on slider widget I have some error. Slider changed his value, but when I click in other part of screen (not fitted in widget) his value still will be changed. Whole screen have focus on this widget only. I use settings to LCD from CubeF7 delivered by STM32 for this dev kit. Also I included part of code responsible for my window which not working. Maybe someone have this same problem, or maybe I use wrong file. I need some adwise where I need go to my project and where probably will search for reason.
static void _cbDialog(WM_MESSAGE * pMsg) {
WM_HWIN hItem;
int NCode;
int Id;
// USER START (Optionally insert additional variables)
// USER END
switch (pMsg->MsgId) {
case WM_INIT_DIALOG:
// Initialization of 'Text'
hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
TEXT_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
TEXT_SetFont(hItem, GUI_FONT_32B_1);
// USER START (Optionally insert additional code for further widget initialization)
// USER END
break;
case WM_NOTIFY_PARENT:
Id = WM_GetId(pMsg->hWinSrc);
NCode = pMsg->Data.v;
switch(Id) {
case ID_SLIDER_0: // Notifications sent by 'Slider'
switch(NCode) {
case WM_NOTIFICATION_CLICKED:
// USER START (Optionally insert code for reacting on notification message)
// USER END
break;
case WM_NOTIFICATION_RELEASED:
// USER END
break;
case WM_NOTIFICATION_VALUE_CHANGED:
// USER END
break;
// USER START (Optionally insert additional code for further notification handling)
// USER END
break;
case ID_BUTTON_0: // Notifications sent by 'Button'
switch(NCode) {
// USER END
break;
// USER END
break;
// USER END
break;
case ID_BUTTON_1: // Notifications sent by 'Button'
switch(NCode) {
// USER END
break;
// USER END
break;
// USER END
break;
// USER START (Optionally insert additional code for further Ids)
// USER END
break;
// USER START (Optionally insert additional message handling)
// USER END
default:
WM_DefaultProc(pMsg);
break;
And I call my window in this way.
WM_HWIN hWin;hWin = CreateSpinBoxTest();
GUI_Exec();
thank you in advance,
Daniel
