2013-06-08 9:29 AM
The datasheets don't detail how these pins are connected internally. Can someone shed some light on this?
Can I use these pins as output compare outputs? i.e. PWM outputs?2013-06-08 10:36 AM
Question about usage of pins like TIM2_CH1_ETR, TIM8_CH4_BKIN2, etc The datasheets don't detail how these pins are connected internally. Can someone shed some light on this?
TIM2_CH1 and TIM2_ETR are connected together for the purpose of interpreting the black box diagram of the timer unit.Can I use these pins as output compare outputs? i.e. PWM outputs? YesWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
