2010-05-18 11:10 PM
pulse generation
2011-05-17 4:51 AM
I needed something similar, In my case I solved using TIMER. Here my code:
[DEAD LINK /public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/fastest way to generate output waveform&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E¤tviews=122]https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fARM%20CortexM3%20STM32%2ffastest%20way%20to%20generate%20output%20waveform&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E¤tviews=1222011-05-17 4:51 AM
Thanks for the reply, in your case, what you did is pwm where the duty cycle and period is set. My problem is to generate a specific number of pulses because my application is for stepper motor where I need to generate the precise number of steps. The PWM is not that important and relevant. Any tips or code on how to do it?
2011-05-17 4:51 AM
Hi again benison,
I don't know if you have looked at the application note ''AN2820'' it is about: ''Driving bipolar stepper motors using a medium-density STM32F103xx microcontroller'' This is the link: http://www.st.com/mcu/familiesdocs-110.html Hope this helps. MCU Lüfter, be low power2011-05-17 4:51 AM
Thanks. I've already solved the problem, I've found a much easier way, alternating the GPIO pin as set and reset and by having a certain amount of delay for each is much easier. This way, I can control the duration of the pulse and how much pulse I wanted to produce by using for loop. If there's any question on how to do this, I'll be happy to post the code.
2014-06-03 3:29 AM
Can you share again code.It is very userful for me.Thanks2014-06-03 3:30 AM
Can you share again code.It is very userful for me.Thanks2014-06-03 3:36 AM
Original thread date 2010, the 2011 date is when the forum had it's last big meltdown. Assume the posters are unlikely to be here or respond.
