2024-01-15 1:18 AM
i have an issue with my timer interrupt that every 500 us happends and external interrupts (12EXTI) .
when the timer interrupt happend , the external interrupts never execute.
i dont know why this is happening.
i mean it supposed to pending for other interrupts but it looks like this is not happening
2024-01-15 1:31 AM
Let me guess... oops, not possible without further info. ;)
So please:
- which STM32?
- show some relevant source code (interrupt enable, priorities, handlers)
2024-01-15 2:00 AM
stm32f446
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
// Set the counter value to zero
htim3.Instance->CNT = 0;
n2 = 0;
HAL_ADC_Start(&hadc2);
HAL_ADC_Start(&hadc3);
if (HAL_ADC_PollForConversion(&hadc2, 1000) == HAL_OK)
adc_value2 = HAL_ADC_GetValue(&hadc2);
if (HAL_ADC_PollForConversion(&hadc3, 1000) == HAL_OK)
adc_value3 = HAL_ADC_GetValue(&hadc3);
if( adc_value3 > data_max )
n2 = 1;
adc_value3 = adc_value2 ;
if(n2 == 0)
adc_value3 = adc_value3/2 ;
//Filter Part
data_dac = ( 2.3/3 )* data;
HAL_DAC_SetValue(&hdac, DAC_CHANNEL_1, DAC_ALIGN_12B_R, data_dac);
if (data <= ( limitPercentage1 * data_max ) )
if ( ( HAL_GPIO_ReadPin(GPIOB, RELAY_GPIO_PIN) == GPIO_PIN_RESET ) && ( HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_4) == GPIO_PIN_SET ) )
//ON RELAY
HAL_GPIO_WritePin(GPIOB, RELAY_GPIO_PIN, GPIO_PIN_SET); //A0
//OFF RED LED
HAL_GPIO_WritePin(GPIOB, LED_GPIO_PIN, GPIO_PIN_RESET);
//Give permission to operator to reset micro
HAL_GPIO_WritePin(GPIOB , GPIO_PIN_5 , GPIO_PIN_SET); //A1
else
//HAL_Delay( lowestDelay1 * 1000 );
//Turn off Relay
HAL_GPIO_WritePin(GPIOB, RELAY_GPIO_PIN, GPIO_PIN_RESET); //A0
//ON RED LED
HAL_GPIO_WritePin(GPIOB, LED_GPIO_PIN, GPIO_PIN_SET);
//Get permission off operator to reset micro
HAL_GPIO_WritePin(GPIOB , GPIO_PIN_5 , GPIO_PIN_RESET);
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
/* Prevent unused argument(s) compilation warning */
UNUSED(GPIO_Pin);
while(keyOk < 3 )
lowestDelay = 0;
setGain = 0;
gainStatus = 0;
if (HAL_GPIO_ReadPin(GPIOC, GAIN_CONTROL_PIN_1) == GPIO_PIN_SET) {
gainStatus++;
setGain = 10;
else if (HAL_GPIO_ReadPin(GPIOB, GAIN_CONTROL_PIN_2) == GPIO_PIN_SET) {
gainStatus++;
setGain = 25;
else if (HAL_GPIO_ReadPin(GPIOC, GAIN_CONTROL_PIN_3) == GPIO_PIN_SET) {
gainStatus++;
setGain = 50;
else if (HAL_GPIO_ReadPin(GPIOC, GAIN_CONTROL_PIN_4) == GPIO_PIN_SET) {
gainStatus++;
setGain = 100;
else {
setGain = 300;
// Check if at least two GPIOs are set to 1
if (gainStatus < 2)
keyOk++;
setGain = setGain ;
if((keyOk > 2) & (n == 0))
keyOk = 2;
else
keyOk--;
if(keyOk < 0)
keyOk = 0 ;
// Calculate the delay percentage based on the active switches
limitPercentage = 0;
if (HAL_GPIO_ReadPin(GPIOC, LIMIT_CONTROL_PIN_1)== GPIO_PIN_SET)
limitPercentage += 10;
if (HAL_GPIO_ReadPin(GPIOC, LIMIT_CONTROL_PIN_2)== GPIO_PIN_SET)
limitPercentage += 20;
if (HAL_GPIO_ReadPin(GPIOA, LIMIT_CONTROL_PIN_3)== GPIO_PIN_SET)
limitPercentage += 40;
if (HAL_GPIO_ReadPin(GPIOA, LIMIT_CONTROL_PIN_4)== GPIO_PIN_SET)
limitPercentage += 80;
// Check if the sum exceeds 90%
if (limitPercentage <= 90)
keyOk++;
limitPercentage = limitPercentage ;
keyOk = 2;
else
keyOk--;
if(keyOk < 0)
keyOk = 0 ;
if (HAL_GPIO_ReadPin(GPIOA, DELAY_CONTROL_PIN_1)== GPIO_PIN_SET ) lowestDelay = 1;
if (HAL_GPIO_ReadPin(GPIOA, DELAY_CONTROL_PIN_2)== GPIO_PIN_SET ) lowestDelay = (lowestDelay == 0) ? 2 : lowestDelay;
if (HAL_GPIO_ReadPin(GPIOB, DELAY_CONTROL_PIN_3)== GPIO_PIN_SET ) lowestDelay = (lowestDelay == 0) ? 4 : ((lowestDelay < 4) ? lowestDelay : 4);
if (HAL_GPIO_ReadPin(GPIOB, DELAY_CONTROL_PIN_4)== GPIO_PIN_SET ) lowestDelay = (lowestDelay == 0) ? 8 : ((lowestDelay < 8) ? lowestDelay : 8);
if ( keyOk == 2)
keyOk = 1;
n = 1;
else if ( keyOk < 2)
keyOk = 0 ;
keyOk = 2 ;
//Set potentiometer Based on GPIO That connect by DIP switches
// Set the MCP41010 resistance to 3.7 kohms (0x70).
MCP41010_SetResistance(&hspi1, 0x70);
// Set the MCP41010 resistance to 5 kohms (0xA0).
MCP41010_SetResistance(&hspi1, 0xA0);
// Set the MCP41010 resistance to 7 kohms (0xD0).
MCP41010_SetResistance(&hspi1, 0xD0);
// Set the MCP41010 resistance to 8.5 kohms (0xF0).
MCP41010_SetResistance(&hspi1, 0xF0);
limitPercentage1 = limitPercentage ;
lowestDelay1 = lowestDelay ;
HAL_ADC_Start(&hadc1);
if (HAL_ADC_PollForConversion(&hadc2, 1000) == HAL_OK) {
//m1 = HAL_ADC_GetValue(&hadc2);
HAL_GPIO_WritePin(GPIOB , GPIO_PIN_7 , GPIO_PIN_SET); // A3
//HAL_Delay(5);
while(1)
//m2 = HAL_ADC_GetValue(&hadc2);
//HAL_Delay(5);
if ( m2 > m1 )
m1 = m2;
n1 = 0;
else
n1++;
if (n1>=2)
// Read the value of setGain and Compare the range of m1 for each value
if(setGain == 10)
if( ( 100 < m1 ) && ( m1 < 200 ) )
//HAL_TIM_Base_Start_IT(&htim3);
break;
else
HAL_GPIO_WritePin(GPIOB , GPIO_PIN_8 , GPIO_PIN_SET); //RESET MICRO USING MAX6962
if(setGain == 25)
if( ( 100 < m1 ) & ( m1 < 200 ) )
break;
else
if(setGain == 50)
break;
else
if(setGain == 100)
break;
else
if(setGain == 300)
break;
else
// 3 times toggle LED
for (int q=0;q<60000;q++);
//HAL_Delay(300);
for (int q=0;q<60000;q++) ;
//HAL_Delay(300);
// HAL_Delay(300);
// HAL_Delay(300);
// HAL_Delay(300);
2024-01-15 2:02 AM
static void MX_TIM3_Init(void)
/* USER CODE BEGIN TIM3_Init 0 */
/* USER CODE END TIM3_Init 0 */
/* USER CODE BEGIN TIM3_Init 1 */
/* USER CODE END TIM3_Init 1 */
htim3.Instance = TIM3;
htim3.Init.Prescaler = 1000-1;
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 45-1;
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
Error_Handler();
if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
Error_Handler();
HAL_NVIC_SetPriority(TIM3_IRQn, 0 , 0);
HAL_NVIC_EnableIRQ(TIM3_IRQn);
/* USER CODE BEGIN TIM3_Init 2 */
/* USER CODE END TIM3_Init 2 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_11|GPIO_PIN_12, GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOD, GPIO_PIN_2, GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7, GPIO_PIN_RESET);
/*Configure GPIO pins : PC3 PC4 PC5 */
GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING_FALLING;
GPIO_InitStruct.Pull = GPIO_PULLDOWN;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/*Configure GPIO pins : PB1 PB2 PB13 PB14
PB15 */
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_13|GPIO_PIN_14
|GPIO_PIN_15;
/*Configure GPIO pins : PA9 PA10 PA11 PA12 */
GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
/*Configure GPIO pins : PC11 PC12 */
GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
/*Configure GPIO pin : PD2 */
GPIO_InitStruct.Pin = GPIO_PIN_2;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/*Configure GPIO pins : PB3 PB5 PB6 PB7 */
GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
/*Configure GPIO pin : PB4 */
GPIO_InitStruct.Pin = GPIO_PIN_4;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
/* EXTI interrupt init*/
HAL_NVIC_SetPriority(EXTI1_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(EXTI1_IRQn);
HAL_NVIC_SetPriority(EXTI2_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(EXTI2_IRQn);
HAL_NVIC_SetPriority(EXTI3_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(EXTI3_IRQn);
HAL_NVIC_SetPriority(EXTI4_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(EXTI4_IRQn);
HAL_NVIC_SetPriority(EXTI9_5_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(EXTI9_5_IRQn);
HAL_NVIC_SetPriority(EXTI15_10_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
2024-01-15 3:00 AM
There is this nice little forum option "</>" for source code input, which is unfortunately hidden in the 2nd row, so first click this "...", then you see "</>".
Otherwise the code is not readable that well. And please only post what might actually be needed.
2024-01-15 3:20 AM - edited 2024-01-15 3:23 AM
Here's the NVIc Config for External interrupts
Here's The Callback Function for Timer 3 interrupt:
n2 = 0;
//if (HAL_ADC_PollForConversion(&hadc2, 1000) == HAL_OK)
//if (HAL_ADC_PollForConversion(&hadc3, 1000) == HAL_OK)
n2 = 1;
if(n2 == 0)
//Filter Part
//ON RELAY
//OFF RED LED
else
//Turn off Relay
//ON RED LED
Here's Timer3 Config:
htim3.Init.Period = 9000-1;
Error_Handler();
Error_Handler();
Error_Handler();
