2012-11-15 8:01 AM
Hey Folks,
I know it is possible to reset processor with NVIC_SystemReset(). However, is it possible to enforce a _full_ power-off -> power-on reset from inside the code? Cheers2012-11-15 9:31 AM
Well probably not in the sense you want, but you could use a GPIO pin to suppress an external regulator, or loop back to -RESET STANDBY turns off some internal regulators, and exits via a reset. But basically if you want the supply to go away, you'll have to make it really go away.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
