2016-06-24 3:20 PM
I'm using 4.14 (although I had the same behavior with the most recent build on a different machine) under OS X
When configuring the USB devices on an stm32f303VEx, the pins are not correctly configured -- indeed there is no configuration for these pins generated. Furthermore, the only thing I seem to be able configure through the user interface is the user label. This is true within the pin configuration window as described in the user manual. For example, under the USB device configuration, selecting the pins only allows the user label to be changed.This is both unexpected and annoying behavior -- is there some mechanism I am missing ?2016-06-26 1:30 AM
Hi brown.geoffrey.001,
Please upgrade to latest CubeMX 4.15.1 release, then tell us if your issue persists.Syrine-2016-06-27 5:20 AM
2016-06-27 7:03 AM
What do you mean by “the pins are not correctly configured -- indeed there is no configuration for these pins generated�?Could you please provide more explanation on your case, so that it will be easier to understand the issue?-Syrine-2016-06-27 9:43 AM
Src/usbd_conf.c
From: SyrinePosted: Monday, June 27, 2016 4:03 PMSubject: Pin configuration in cubemx broken ?
What do you mean by “the pins are not correctly configured -- indeed there is no configuration for these pins generated�?Could you please provide more explanation on your case, so that it will be easier to understand the issue?-Syrine-2016-06-28 3:33 AM
could you please share your .ioc file for check?-Syrine-2016-06-28 2:07 PM
2016-06-29 1:44 AM
I'll report this issue to our MX team for checking. Sorry for the inconvenience it may bring.-Syrine-We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
