2013-12-10 3:32 AM
heloo,
I have problem ?how to use
the null-modem female/female RS232 cable between the DB9 connectr CN16 (USART3) and PC serial ??can you give me a picture please ?
#lmgtfy #first-principles #ask-better-questions2013-12-10 4:47 AM
Google for the PC pinout;
Look at the board schematic for the board pinout;Take care to understand which are inputs and which are outputs (don't just assume that ''RX'' means input - it doesn't necessarily);You should be able to take it from there...2013-12-10 6:20 AM
STM324x9I-EVAL board?
Just connect them together?http://www.cablesforless.com/DB9-Female-Female-Null-Modem-Cables-C345.aspx
should work. Pin out if you're interestedhttp://www.aggsoft.com/rs232-pinout-cable/nullmodem-db9-to-db9.htm
