2015-04-23 3:07 AM
Hello
Is it sufficient to supply ov7670 camera module xclk pin with MCO1/2 pins of stm32f4?2015-04-28 8:38 AM
You asked the same question at least 6 times in this forum mainly updating old discussions. As suggested by Clive1 , you will not get the help you look for if you don't provide enough details about your case: the problem you are facing, used hardware, what did you tested and what is going wrong... -Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
