2014-12-23 12:53 PM
I'm stepping through my code to see where a certain bug occurs with my display driver, and found that something strange is going on. An instance of the class gets initialized properly, but once I try to use a method of that class, the pointer value seems to have been changed somehow.
I appear to initialize correctly...Display * volatile const sys_disp = new Display();
(gdb) p sys_disp $1 = (Display * const volatile) 0x20002638 ...but the value gets changed once I want to to use it.sys_disp->write_all_lines();
(gdb) p sys_disp $2 = (Display * const volatile) 0x0 Any ideas as to how I can keep the value the way it was? Why is this happening? I'll be happy to provide more debug output if necessary. #debug #volatile #optimizations2014-12-24 4:13 AM
As far as I know, to be ''optimised out'' means that the compiler has decided that the variable is not needed long-term, so it does not need to be stored in memory.
First question:Is this a global variable (i.e. outside the scope of all functions)?Otherwise, unless it is declared static, it will not retain its value between function calls.Second question:How strongly do you know that your code is not clobbering the variable by e.g. writing beyond the end of a buffer that happens to be nearby in memory?Can you put a breakpoint on all writes to that memory location? (I don't know how you'd do that in gdb; I use Rowley Crossworks which has that ability).Hope this helps,DanishWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
