2018-05-13 12:19 PM
Hi, I am looking for bsp in keil for nucleo144 board but i am not able to find it in the latest version of the keil. Where can i find the bsp for the same? What is the procedure?
2018-05-13 8:50 PM
Yes,
BSP, it is not an easy request.
Nucleo-144 is a generic form factor. Not a chip.
there is no BSP for a form factor.
I use the CubeMx to generate the base init code.
2018-05-13 9:08 PM
The HAL/Cube trees have assorted BSP code. For Keil specific stuff you should probably contact your support/sales representative at Keil if the code you want isn't in the Packs.
