2025-04-21 2:39 AM - last edited on 2025-04-21 2:56 AM by mƎALLEm
需要寻求帮助,我使用STM32H563VIT6配置了一个引脚输出高低电平,在debug模式下可以运行,在正常运行(release)下就不能得到结果,这是为什么?而且我是在HSE不行还用了HSI也不行
Translation:
I need help. I used STM32H563VIT6 to configure a pin to output high and low levels. It works in debug mode, but not in normal operation (release). Why? And I used HSI but it didn't work in HSE.
2025-04-21 3:00 AM - edited 2025-04-21 3:02 AM
Hello @WYS666 and welcome to the community,
First please use English language in this community.
What board are you using?
For the GPIO level could you please share your project?
2025-04-22 2:00 AM
Welcome to the forum.
As @mƎALLEm said, more details are needed in order to help you - please see How to write your question to maximize your chances to find a solution for guidance.
@WYS666 wrote:It works in debug mode, but not in normal operation (release).
So what, exactly, happens in Release ?
If it works in Debug, then your hardware must be OK - so the problem must be somewhere in your software.
Maybe it's crashing before it gets to toggling the pin?
Try to create a minimum but complete project which illustrates the issue.
@WYS666 wrote:And I used HSI but it didn't work in HSE.
What, exactly, do you mean by that?
