2020-02-03 1:01 PM
2020-02-03 1:08 PM
Try a different cable, charging cables probably won't work.
2020-02-03 1:16 PM
But the power goes into the board as it flashes a red light or that doesn't mean anything.
2020-02-03 1:53 PM
Charging cables generally succeed in connecting power, communications not so much. Like I said try using a different cable
2020-02-04 1:37 AM
It might contain a demo firmware that flashes some LEDs.
Try plugging it in a USB2 port or a powered USB2 hub, might work better as USB3.
But check the cable first, does it work with some other USB device, e.g. a smartphone?
