2017-05-26 5:59 AM
I don't understand why there is a limitation on output channel that can be used in driver in OnePulse mode.
HAL_TIM_OnePulse_ Start specifies that only CH1 or CH2 can be used as output. Why cant other channels be used as output?
I understand why CH1 or CH2 has to be used as input.
#one-pulse #stm32l4-timer2017-05-26 6:44 AM
Which mcu, which timer?
2017-05-26 7:04 AM
Hi
ringheim.ian
,Which firmware version are you using ?
