2025-03-21 2:31 AM - last edited on 2025-03-21 2:55 AM by Andrew Neil
Hi All,
We are currently working with the STM32U083RCT6 microcontroller for a capacitive touch switch and LED drive design. While all other functions are working correctly, we are encountering issues with the touch sensing functionality on pins PB5, PB6, and PB7.
Here are the details of our setup and the issue:
Could you kindly provide guidance on the following points:
We have verified the capacitive pad design, and environmental factors (such as grounding, shielding, and power supply quality) seem fine. Still, we are struggling with getting a reliable touch response.
We appreciate your time and assistance resolving this issue and look forward to your expert guidance.
2025-03-21 5:15 AM
Getting started with touch sensing control on STM32 MCUs - Application note
2025-03-21 6:30 AM
Hi Guru,
Thank you for your previous response. We have followed the guidelines provided in the application note "Getting Started with Touch Sensing Control on STM32 MCUs" as suggested. However, we are still facing issues with the touch sensing functionality not working as expected.
Could you please advise if there are any additional software configurations required? Also, should we be making any changes to the circuit or hardware setup?
Any insights or suggestions you could provide would be greatly appreciated.
Regards,
Sathiya
