2021-02-11 5:11 AM
2021-02-11 5:18 AM
The Reference Manual, and the bus matrix diagrams.
The DMA to use would depending on the source / destination of the transfer, most usually the memory being used.
2021-02-11 5:27 AM
Why should I use MDMA instead of DMA? I searched and I read some documents but I am not satisfied with what I read.
2021-02-11 6:08 AM
As Clive said above, read the Reference Manual, not "some documents". Yes, it's 3000+ pages long, and what. Rome wasn't built in a day. It was your choice to go for the most complex STM32 available. And you don't need to read it all, anyway, see index/bookmarks.
2021-02-11 6:42 AM
Hello @Ali Aldoğan,
I recommend you to have a look to:
https://community.st.com/s/question/0D50X0000A4nsm2SQA/mdma-vs-dma
You can also refer to application note: AN5001
https://www.st.com/content/ccc/resource/technical/document/application_note/group0/56/d6/da/be/34/2c/4f/94/DM00360392/files/DM00360392.pdf/jcr:content/translations/en.DM00360392.pdf
Imen,
2021-02-11 7:56 AM
@Community member , @Imen GH , @Community member Thank you. I am much more better now about rome :)
