2021-05-08 3:49 AM
In STM32G030x6/x8 datasheet (DS12991 Rev 3, Table 12 on page 31) I see only input pin for external HSE clock source (LQFP32, pin 2 - PC14 - OSC_IN), but don't see OSC_OUT pin of HSE OSC.
2021-05-08 5:50 AM
It doesn't have an OSC_OUT pin, so it needs an external clock source for HSE and can only run in bypass mode.
2021-05-10 11:23 AM
Thanks for your reply. It is a pity, that the documentation does not explicitly state that the HS OSC of the STM32G030 MCUs in the TSSOP20 and LQFP32 packages can only work from an external clock generator.
