2015-03-05 5:52 AM
Dear Sir/Miss,
I need 2 alarms, I only can get one alarm work thought Canlandar module, but if make code for alarm A and B, none of them works. Here is my code: ********** RTC_TimeTypeDef RTC_TimeStructure; RTC_AlarmTypeDef RTC_AlarmStructure; RTC_GetTime(RTC_Format_BIN, &RTC_TimeStructure); sec = RTC_TimeStructure.RTC_Seconds; min = RTC_TimeStructure.RTC_Minutes; hour = RTC_TimeStructure.RTC_Hours; Alarm_Init(); /* Alarm A */ RTC_GetAlarm(RTC_Format_BIN, RTC_Alarm_A, &RTC_AlarmStructure); RTC_AlarmCmd(RTC_Alarm_A, DISABLE); /* Disable the RTC Alarm A Interrupt */ RTC_ITConfig(RTC_IT_ALRA, DISABLE); RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = (sec+0X01); RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = (min+0X01); RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours = (hour+0X00); RTC_AlarmStructure.RTC_AlarmDateWeekDaySel = RTC_AlarmDateWeekDaySel_Date; RTC_AlarmStructure.RTC_AlarmDateWeekDay = day; RTC_SetAlarm(RTC_Format_BIN, RTC_Alarm_A, &RTC_AlarmStructure); /* Enable the RTC Alarm A Interrupt */ RTC_ITConfig(RTC_IT_ALRA, ENABLE); /* Enable the alarm A */ RTC_AlarmCmd(RTC_Alarm_A, ENABLE); /* Alarm B */ RTC_GetAlarm(RTC_Format_BIN, RTC_Alarm_B, &RTC_AlarmStructure); RTC_AlarmCmd(RTC_Alarm_B, DISABLE); /* Disable the RTC Alarm B Interrupt */ RTC_ITConfig(RTC_IT_ALRB, DISABLE); RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = (sec+0X01); RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = (min+0X00); RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours = (hour+0X00); RTC_AlarmStructure.RTC_AlarmDateWeekDaySel = RTC_AlarmDateWeekDaySel_Date; RTC_AlarmStructure.RTC_AlarmDateWeekDay = day; RTC_SetAlarm(RTC_Format_BIN, RTC_Alarm_B, &RTC_AlarmStructure); /* Enable the RTC Alarm B Interrupt */ RTC_ITConfig(RTC_IT_ALRB, ENABLE); /* Enable the alarm B */ RTC_AlarmCmd(RTC_Alarm_B, ENABLE); ***************** void RTC_Alarm_IRQHandler(void) { /* Clear the EXTIL line 17 */ EXTI_ClearITPendingBit(EXTI_Line17); /* Check on the AlarmA falg and on the number of interrupts per Second (60*8) */ if (RTC_GetITStatus(RTC_IT_ALRA) != RESET) { // STM_EVAL_LEDOn(LED4); alarm_now2 = 0; /* Clear RTC AlarmA Flags */ RTC_ClearITPendingBit(RTC_IT_ALRA); RTC_HandlerFlag = ENABLE; } if (RTC_GetITStatus(RTC_IT_ALRB) != RESET) { // STM_EVAL_LEDOn(LED4); alarm_now = 0; /* Clear RTC AlarmA Flags */ RTC_ClearITPendingBit(RTC_IT_ALRB); RTC_HandlerFlag = ENABLE; } } ~~~~~~~~~~~~~~~~~~~~~~ Please help Thanks2015-03-05 10:06 AM
Would suggest you advance it more than a second, and also roll the seconds/minutes/hours properly.
2015-03-05 1:15 PM
I change
~~~~~~~~~~~~ RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = (sec+0X01); RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = (min+0X00); to: RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = (sec+0X01); RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = (min+0X02); ~~~~~~~~~~~~~~~~~~~~~ Still both of alarm A and Alarm B do not work.2015-03-05 2:02 PM
Check on link below, maybe it will be helpful to you.
http://stm32f4-discovery.com/2014/07/library-19-use-internal-rtc-on-stm32f4xx-devices/2015-03-05 2:11 PM
Please try to make a complete, free standing example.
In your system review the peripheral/register states to understand what might be going on.2015-03-05 8:36 PM
I have this and it works for me..
void AlarmTest(void)
int sec, min, hour;
int secA, minA, hourA;
int secB, minB, hourB;
AlarmInit(); // Initialize NVIC and EXTI
/* Wait for RTC APB registers synchronisation - Defensive in case your code's broken */
RTC_WaitForSynchro();
/* Get Current Time */
printf(''Current %02d:%02d:%02d
RTC_TimeStructure.RTC_Hours,
RTC_TimeStructure.RTC_Minutes,
RTC_TimeStructure.RTC_Seconds);
/* ALARM A */
secA = sec + 1; // At +00:01:01
minA = min + 1;
hourA = hour;
if (secA >= 60) // Rollover
secA -= 60;
minA++;
if (minA >= 60)
minA -= 60;
hourA++;
if (hourA >= 24)
hourA -= 24;
printf(''Alarm A %02d:%02d:%02d
'', hourA, minA, secA);
/* Get Current Alarm A */
/* Disable the Alarm A */
RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = secA;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = minA;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours = hourA;
RTC_AlarmStructure.RTC_AlarmDateWeekDay = 31; // Ignored
RTC_AlarmStructure.RTC_AlarmMask = RTC_AlarmMask_DateWeekDay;
RTC_ClearFlag(RTC_FLAG_ALRAF);
/* ALARM B */
secB = sec + 1; // At +00:02:01
minB = min + 2;
hourB = hour;
if (secB >= 60) // Rollover
secB -= 60;
minB++;
if (minB >= 60)
minB -= 60;
hourB++;
if (hourB >= 24)
hourB -= 24;
printf(''Alarm B %02d:%02d:%02d
'', hourB, minB, secB);
/* Get Current Alarm B */
/* Disable the Alarm B */
RTC_AlarmStructure.RTC_AlarmTime.RTC_H12 = RTC_H12_AM;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = secB;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = minB;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours = hourB;
/* Enable the Alarm B */
RTC_ClearFlag(RTC_FLAG_ALRBF);
/* Check on the AlarmA flag */
/* Clear the EXTI line 17 */
puts(''AlarmA Hit'');
/* Check on the AlarmB flag */
/* Clear RTC AlarmB Flags */
puts(''AlarmB Hit'');
