2020-04-22 1:36 AM
RM0008 Rev 20
Section 24.4.1 Initialization mode
Paragraph 2 mentions INQR bit. Should be INRQ bit.
Figure 235 CAN frames
Shows arbitration fields as all 32 bits length
First arbitration field in a frame should be 11 bits length, 2nd (where existing) should be 18 bits
2020-04-22 9:01 AM
Hello @jblai.1 ,
Thank you for your remark.
I will check it and I will raise internally to take into consideration
Regards,
