2014-10-09 1:25 PM
I am just installed the STLink and Yagarto on my Mac OS 10.9.5 and it took me 3 days:( . I started the instance of STLINK by using command :./st-util --stlinkv1
and after that I opened another terminal to run the GDB:tcms-MacBook-Pro:yagarto-4.7.2 Ruslan$ arm-none-eabi-gdb /Users/Ruslans/STM32-Template/BlinkingLight.elf
but when I try to load the .elf by by using command(gdb) target extended-remote :4242
I get this error:Remote debugging using :4242
0x08000b4c in GPIO_Write (GPIOx=0xa, PortVal=<optimized out>)
at /l/arm/STM32F10x_StdPeriph_Lib_V3.5.0/Libraries/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.c:423
423 /l/arm/STM32F10x_StdPeriph_Lib_V3.5.0/Libraries/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.c: No such file or directory.
I am very new to unix based systems or to GDB and GCC so I have problem with fixing this issue. Could someone advice on how to address this problem? I started by loading the STM32VL library into my project folder STM32 Template but the error persists. I don't understand why gdb is looking for thestm32f10x_gpio.c since the .elf file is already a compiled and ready to be loaded object. Please help.
2014-10-09 2:52 PM
I used this tutorial for OSX, helped me out.
http://www.davidrojas.co.uk/stm32f3discovery-on-mac-os-x-using-eclipse-gcc-arm-and-openocd/2014-10-09 3:23 PM
Thank you but I would like to avoid for now the use of IDE in order to gain a better understanding of programming the STM32.
I am using this tutorial from Illinois University:http://www.cs.indiana.edu/~geobrown/book.pdfWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
