2018-09-13 9:59 AM
Hope someone can help me. I try to construct a STM32H753 based control module that will communicate with other modules in the network through a 1000 mbps ethernet port, that is a system requirement. How can I connect STM32H753 with the 1000 mbps PHY chip?
Thank you!
Bryan L
2018-09-13 10:50 AM
You can't, the STM32 don't have GMII/RGMII.
OTOH, what would be the rationale for such a requirement? The STM32 hardly can provided a sustained gigabit stream, and 100M devices can merrily coexist on gigabit switches, can't they?
2018-09-14 12:08 AM
If the device must have gigabit support, you can go for a higher performance chip, or add a gigabit switch IC in between.
