2023-05-30
2:20 AM
- last edited on
2023-07-19
2:13 AM
by
Laurids_PETERSE
Tool & Version: Motor Control Work Bench 5.Y.4
Cube MX: V6.8.1
FW: 1.11.4
Create the new project as below:
Code generation error:
Log detial:
I had tried to slove the problem in following way:
a) Use the direct path to instead of relative path; ----
Direct path: D:\Software Install\MC_SDK_5.Y.4\Middlewares\ST\MotorControlmodify in the config file: wb2mx.properties
b) Use the recommand FW version: FW1.11.3 ---- Problem still;
c) Install Motor Control Work Bench 5.4.8 ---- Same problem;
Does anyone have the same problem? Any suggestion?
2023-07-07 8:26 AM
Hello, I apologize for the late response. I would like to help you but the images do not seem to be displaying correctly, can you please check them.
