HFI & X-CUBE-MCSDK
Luca Zechner
Associate
When will the HF-Injection feature be enabled for the MCSDK_v5.x.x?
I figured out, that it has been enabled in the v4.3, but in v5.2 it is only declared as "Available in a later release". Is there a possibilty to estimate a date, when this feature will be enabled?
Thanks for your answer.
3 REPLIES 3
Claire O.
Dear Luca,
We decided not to port the HFI in the MCSDK5.x. Indeed it works only with a limited number of motors. We are now thinking to replace HFI by a new algorithm. It will not be available before end 2019. Sorry for the inconvenience,
Best regards,
Claire
Luca Zechner
Associate
Hallo Claire,
thank you for your answer.
Ist there a other method to achieve standstill torque with the X-CUBE-MCSDK?
If it's possible sensorless.
Kind regards,
Luca
Laurent Ca...
Lead II
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
