2018-10-26 4:01 AM
I am using a nucleo-f302r8 and x-nucleo-ihm07m1 in order to controll a BLDC motor. I have installed the (ST Motor control workbench). when I run the st motor profiler and try to connect, I see the following message:
"unable to identify the exact number of boards connected by means of ST-LINK"
I have installed and upgraded ST-LINK usb driver properly. I use windows 10.
I appreciate your help to solve this connection problem
2020-04-30 12:30 AM
did you solved your problem?
2021-06-22 2:10 AM
The question has been moved from the section "Motor Control Hardware" to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
