2022-01-16 9:48 PM
Hi everyone,
I am using X-CUBE-CELLULAR v6.0 and would like to use DMA on UART to replace the original interrupt receiving method.
The original method is calling IPC_RXFIFO_writeCharacter() in HAL_UART_RxCpltCallback() and notify upper layer when an end of message is received.
Seems I need to modify the functions above and the codes below in ATCoreTaskBody() to receive a block of UART bytes and parse them in ATCoreTaskBody()
if (msg == (SIG_IPC_MSG))
/* retrieve message from IPC */
if (IPC_receive(&ipcHandleTab, &msgFromIPC) == IPC_ERROR)
TRACE_DBG("IPC receive error")
ATParser_abort_request(&at_context);
TRACE_DBG("**** Sema Released on error 1 *****")
(void) rtosalSemaphoreRelease(s_WaitAnswer_SemaphoreId);
/* skip this loop iteration */
continue;
/* one message has been read */
IRQ_DISABLE();
MsgReceived--;
IRQ_ENABLE();
/* Parse the response */
#if (USE_PARSING_MUTEX == 1)
(void)rtosalMutexAcquire(ATCore_ParsingMutexHandle, RTOSAL_WAIT_FOREVER);
#endif /* USE_PARSING_MUTEX == 1 */
action = ATParser_parse_rsp(&at_context, &msgFromIPC);
(void)rtosalMutexRelease(ATCore_ParsingMutexHandle);
/* analyze the response (check data mode flag) */
action = analyze_action_result(action);
/* add this action to action flags only if this kind of action will be treated later */
if ((action == ATACTION_RSP_FRC_END)
|| (action == ATACTION_RSP_FRC_CONTINUE)
|| (action == ATACTION_RSP_ERROR))
at_context.action_flags |= action;
TRACE_DBG("add action 0x%x (flags=0x%x)", action, at_context.action_flags)
if (action == ATACTION_RSP_ERROR)
TRACE_ERR("AT_sendcmd error")
TRACE_DBG("**** Sema Released on error 2 *****")
continue;
/* check if this is an URC to forward */
if (action == ATACTION_RSP_URC_FORWARDED)
/* notify user with callback */
if (register_URC_callback != NULL)
/* get URC response buffer */
do
(void) memset((void *) urc_buf, 0, ATCMD_MAX_BUF_SIZE);
retUrc = ATParser_get_urc(&at_context, urc_buf);
if ((retUrc == ATSTATUS_OK) || (retUrc == ATSTATUS_OK_PENDING_URC))
/* call the URC callback */
(* register_URC_callback)(urc_buf);
} while (retUrc == ATSTATUS_OK_PENDING_URC);
else if ((action == ATACTION_RSP_FRC_CONTINUE) ||
(action == ATACTION_RSP_FRC_END) ||
TRACE_DBG("**** Sema released *****")
else
/* nothing to do */
}Any suggestion is welcome.
Best,
Sean
