2013-04-28 5:12 AM
I have a problem when I use the USB in the Boot application and then jump to my main app without detach the USB . On the main I open it again but the other side lost connection in between. I try to stop the clock to the USB when I jump but no help.
Is there a simple way or a function that can do USB disconnect so the other side see it as the USB was disconnect? Bar. #usb-disconnect2013-04-29 6:42 AM
