STM32L462 delay in a microsecond(us)
AP_040
Senior
HAL Library provide the HAL_Delay() for millisecond delay. I want to use micro second delay in STM32L4 so how I do it? Is it available in HAL library?
12 REPLIES 12
Piranha
Chief II
> You can simply do a nop loop
No, You can't.
https://developer.arm.com/docs/dui0553/a/the-cortex-m4-instruction-set/miscellaneous-instructions/nop
NOP does nothing. NOP is not necessarily a time-consuming NOP. The processor might remove it from the pipeline before it reaches the execution stage.
Use NOP for padding, for example to place the following instruction on a 64-bit boundary.
Also it doesn't account for time in interrupts
HDaji.1
Senior
I tried the DWT method in my code. It basically works.
However, I have 2 issues:
  1. The delay time is not so accurate; and does not go linear with input value.
  2. I wonder if it's OK to call DWT_Delay_Init(void) multiple times.
